I have a logan 200 and when I try to make cuts it seems to slow down twards the end of the cut, even when taking smaller cuts it does this, I'm not attempting to hog out material but it seems I can only cut at like a thou at a time, any thoughts would be welcome
Is a Logan belt driven? I had a 10" south bend that would do the same thing. It was a belt drive with a leather belt. It turns out the belt was slightly saturated with oil and was slipping on the flat pulley. I changed the leather belt out to an automotive serpentine belt and had much better performance.
