- Jun 17, 2021
- 11
I am in the process of getting my 1875 going since i picked it up. When I picked it up there was a 62 tooth change gear that was with it was broken. There was a 48 tooth gear was there and fine. I am also missing the washer that goes between the change gears. I am trying to figure out the gear selection for threading. Looking at the parts list it shows the change gears as LA-213 and LA -214. LA-213 shows to be a 64 tooth and LA-214 shows to be a 72 tooth. It also shows the gearbox drive gear as a LA-214. The lathe came with a 48 tooth installed on the gearbox drive. I am trying to figure out what I need to get everything right. Please help.
