Loctite For Oily Bushing
Kroll
Dec 23, 2012
1,307
Guys someone here suggested that I use the green loctite to keep my oily bushing in place,but I see there are several to choose from.I figure that just need to kinda hold it in place but may need to remove it one day,so is this what I need??? http://www.mcmaster.com/#91458a340/=11lza3j Sorry guys for all the questions on bronze bushings----kroll
Yes that is the right stuff, I was the one that suggested it. At work we have these glycol pumps from Rotor-Tech, and when I replace the seal adapter, which is a stainless bushing that slides on the motor shaft to adapt for the oil lip seals, they send and recommend green loctite for the seal adapter to hold it in place on the motors shaft, which has a factory keyway cut into it, not very good for a lip seal.... the stainless seal adapter is held firmly in place with the green loctite, and to remove it I use a a small propane torch and just warm it up and pry it off, easy peasy.
Edit
Just so there is no confusion, yes they send 603
Fantastic,thank you for replying back.
