- Nov 14, 2016
- 3,006
So if you have a Sherline then you have an understanding of small. I have one too, and an 8 or 9" lathe will give you quite a bit more working room. I find I still use my Sherline a lot even though I also have a 9" and an 11" lathe. I make a lot of small things and find it very handy, plus I have a ton of the accessories that would be much more expensive on a larger lathe, assuming you could even find them.
I don't have any experience with the 8x16s, but from what I've found on them from reading and videos most should be equal to or better than the higher quality 7x lathes because they are not built to as tight a budget, and they are also fair bit larger and heavier. I'm not aware of another 8x16 that says they offer an inch lead screw.
As far as metric vs standard I can't see why metric wouldn't be preferred for doing metric work, but having the lead screw match the dials, is a benefit as it eliminates a source of error. Metric dials on an inch lead screw would have the same issue as inch dials on a metric lead screw.
If you go with a DRO then it really doesn't matter.
I'm not sure if any one here has one of the Weiss lathes Dro Pro sells, but there are some who have used their DROs and they seem to be one of the higher quality options. If you want to make parts in standard and metric I would think a DRO is a good option, so you don't have to make conversions to the measurements, just push a button. I don't have a DRO on any of my machines. I like the idea but it is down a way on my list of things to do.
