- Dec 26, 2016
- 2,019
Thanks Zoltan for clarifying how you used the UHMW spacer ,I understand it now.I didn't really "fit" anything in the base. The UHMW was used to space the gas strut the correct distance from the base, the strut was then bolts to the UHMW, and then both were lowered down into the column.
Following the instruction that came with the LMS air spring kit, I just measured 14.1/2" from the top of the column and drilled a hole in the center of it.
