- Nov 14, 2016
- 3,012
A few months ago I got the OXA size QCTP from Little Machine Shop. Understand this is essentially the same as the one once sold by A2Z.
While they sell it for the Sherline, the lathe is clearly a tad smaller than ideal for this tool post. I've had to make a few adjustments to use the 1/4" tooling but it works and I'm happy with it. Very nice not to have to set up again every time I change a tool.
The issue I'm having is the cut off tool holder which doesn't seem to fit the lathe at all. At full height it appears to be 1/8-1/4" low, as far as I can tell they sent me the correct tool holder and I've set it up as suggested.
Not the end of the world, cut off tool is typically the last operation, so I've just been swapping out the QCTP for the cut off tool post. I'm mostly just wondering if anyone else is using this on a Sherline and if they have the same issue or has found a solution to it.
