OK. I got a hold of the guy that did the rebuild for me. He's had to deal with this often and here's what he had to say for the benefit of myself and anyone else undertaking this.
First. Don't unbolt the turret without first supporting it as it will fall forward an onto the floor. I figured this myself, but didn't ask him how he knew this!
Second. There are small ears in the base casting below the spider. Loosen the 4 bolts slightly. Remove 2 bolts diagonally from each other. SLOWLY loosen the other 2 bolts so the spider lowers level and sits on the ears.
Remove the bolts. Now lift the turret and install the riser and turret with the new longer bolts. Its a good idea to check the threads for ease of starting in the threads of the spider before installing the riser.
Don't screw up and drop the spider.
