Lets See Your Shop!
Steevo: That is one impressive shop. Congrats. Like Campy I've collected to much stuff for my shop to ever look that organized. Roger
Well here's the pictures of my shop and a couple of small steam engine I've done. My friend who understands computers helped me with this. Hopefully it turn out OK, we'll see. The lathe is a Monarch Model K. The mill is a Millrite on a rolling base, the way guards were courtesy of oldmachinist thanks alot. The little Atlas 10 x 24 was where all this madness started. Roger
rogershopsmall 001.JPG rogershopsmall 002.JPG rogershopsmall 003.JPG rogershopsmall 004.JPG rogershopsmall 009.JPG rogershopsmall 010.JPG
Campy: If you're out there here's a couple of pictures you'll enjoy
I like it and the beemers, it looks like my shop. Every so often I take the bikes out and am amazed at how much room I have. The street rod doesn't help with the room problem either. Thanks for posting them. Campy
I've never been much on keeping a very clean shop as you can see from these pictures of some of my equipment and tooling.
South Bend 16" X 8' bed
Bridgeport 12" x 42" J head
Delta Milwaulkee Toolmaker surface grinder
W.F. Wells 9 X 16 band saw
My first machine bought back in 1982.
End mill selection
Tooling
More tooling
A little more tooling
More
More
Fasteners
And interestingly enough, your first machine looks to be the newest piece of gear there too :))
Cheers Phil
You're right it is the newest. Lathe 1945, mill 1973, surface grinder ?, saw ? and the drill press I bought new to drill back pans in machine control boxes I was doing as a side job.
Okay.
Main bench.
Miter box and sander.
Mill
Old Craftsman 12 tilt head Band saw.
Table saw
Joiner
Small sand blast cabinet
Wood storage.
12 " Planer
Dust collector
Home made Router Table with a 3.5 Hp router under it.
Lathe
My Old and I mean old Drill press a Chin Ho from Taiwan.
I put all new bearings in it a few years back both top and in the Quill all good should last until I am up on the Mantel.
Reloading bench.
One my air Compressors
Plus 5 routers and a Dovetail Jig from Porter cable a Tile saw and other stuff related to wood working plus a wood lathe.
I don't have much in the Way of metal stuff but working on it.
Shop needs a total cleaning will do when the heat gets to be around high of 70 and not the start of the day.
Jeff
Nice shop and really not all that clear, What I mean is every flat surface attracts stuff. When I need to use either of my mills I have to move the stuff some where else.:rofl:
Paul
