    Dismiss Notice
Let's See Your Mini Lathe/mill Setups!
Discussion in 'MINI-LATHE & MINI-MILL INFORMATION' started by heliyardsale, Dec 5, 2015.
  1. heliyardsale
    heliyardsale United States Active Member Active Member
    1
    8
    City:
    Newfield
    State:
    New York
    -Return to Top-
    So I recently purchased both a Sherline 2000 8-way mill and a 4400C DRO package lathe. I'm in the process figuring out how I want to set these machines up. I've been thinking about buying something like this and pulling the casters off to make it stationary. This way I would have plenty of tool storage right under the machines. What are you folks using for your bases? Feel free to post up photos please.
  2. kvt
    kvt Active User Active Member
    665
    113
    City:
    San Antonio
    State:
    Texas
    -Return to Top-
    That looks better than what I have, when I got mine from my father in laws estate. They were each mounted to a metal stand from Sears, with 1" ply over 1" planks it kept things nice and flat, but each machine had it's own stand.
  3. Bamban
    Bamban United States Active User H-M Supporter-Premium
    319
    63
    City:
    Austin
    State:
    Texas
    -Return to Top-
    Here is what I have, very much the same butcher block table top like you have in the picture. Right now I have the mini lathe tucked in right behind the mill.
    brino, Ulma Doctor, royesses and 3 others like this.
  4. jere m
    jere m Active Member Active Member
    12
    8
    City:
    AKRON
    State:
    Ohio
    -Return to Top-
    I dont have any photos of my little 8x12 hft lathe, but i mounted it on a 3 drawer craftsman lower tool box. (Should have found one with more drawers but it was only $10). I reinforced the corners with bedframe angle iron and self tapping sheet metal screws. The bottom was very flimsy too so i made a "movers dolly" with 2x4s and heavy casters. For the top i used ½ inch plywood and covered that with a dog kennel plastic floor pan. The plywood and lathe is bolted down in a few spots with some large fender washers.
  5. higgite
    higgite General Manger - Proofreading Dept. Active Member
    583
    93
    City:
    Houston
    State:
    Texas
    -Return to Top-
    heliyardsale,
    I have a Little Machine Shop 8.5x20 lathe sitting atop the exact tool chest that you have pictured. I left mine on casters so I can roll it in and out of the corner as needed. Plus, I'm tall and like the additional height. The lathe weighs in at 220 lbs plus the drawers are full of tools, tool holders, change gears, spare chucks, etc. Works like a champ.
    Tom
    Edit: I take it back. My tool chest isn't exactly the same as you pictured. Mine is the 46" model with different drawer arrangement. Same brand, same construction, though.
    [​IMG]
    royesses likes this.
  6. heliyardsale
    1
    8
    City:
    Newfield
    State:
    New York
    -Return to Top-
    Thanks everyone, great looking setups.
  7. wrmiller
    wrmiller Chief Tinkerer H-M Supporter-Premium
    1,011
    113
    City:
    Hereford
    State:
    Arizona
    -Return to Top-
    When I had my smaller machines this was a pretty good setup for me.
  8. heliyardsale
    1
    8
    City:
    Newfield
    State:
    New York
    -Return to Top-
    Very nice setup wrmiller
    wrmiller likes this.
  9. epanzella
    epanzella United States Active User Active Member
    209
    63
    City:
    Higganum
    State:
    Connecticut
    -Return to Top-
    Could you explain what's going on in the picture. Lots of interesting things
    I've never seen before.
    darkzero likes this.
  10. Bamban
    319
    63
    City:
    Austin
    State:
    Texas
    -Return to Top-
    The cross slide has 2 AXA QCTP, the back one for parting. There is a DC motor drive for cross slide as these do not have power drive for facing or parting. The large handwheel is to drive the the TS.
    The control boxes you see on the top left, one is for the DC motor driving the spindle, the other is the DRO box. The latter is not being used right now.
    Here is how I use the steering wheel on the TS, turning cartridge case necks.
    In case you are wondering what large gear sticking out on the left side of the HS in the original picture, it is normally the middle gear, I swapped it with gear box drive gear to slow down the carriage drive when turning. On manual operation I just kick out to disengage it, so I don't have to run the gear box.
    I do not use this lathe for threading, I will eventually remove the cross slide and just bolt on a metal block for the QCTP.
    Ulma Doctor, DAT510, tweinke and 6 others like this.
  11. epanzella
    209
    63
    City:
    Higganum
    State:
    Connecticut
    -Return to Top-
    Thanks for the tour.
  12. DAT510
    DAT510 United States H-M Supporter - Premium Content H-M Supporter-Premium
    110
    43
    City:
    San Mateo
    State:
    California
    -Return to Top-
    Bamban, I like your sliding tail stock mod. Can you show us more of how you converted it?
  13. Cavediver
    Cavediver United States H-M Supporter - Premium Content H-M Supporter-Premium
    37
    28
    City:
    Buford
    State:
    Georgia
    -Return to Top-
    I'll fill in the low-rent end of the spectrum...
    This is a temporary setup. The top is 2 layers of 3/4 MDF with white laminate on all faces to help resist movement from changes in humidity (a serious problem in Georgia). The laminate is also impervious to most solvents, fluids,etc., resists dings and dents, is easy to clean, and it provides a nice surface for jotting down notes, measurements, etc.
    IMO, that wood top would look nice, but you should use it elsewhere and drop in a laminated version instead.
    Eventually I will have a decent cabinet under it, but the sawhorse setup works well enough for now :grin:
  14. DHarris
    DHarris United States H-M Supporter - Premium Content H-M Supporter-Premium
    53
    18
    City:
    Rohnert Park
    State:
    California
    -Return to Top-
    Cavediver, can I join you in the low-rent end of the spectrum? IMG_20170618_173927888.jpg
    brino likes this.
  15. Zathros
    Zathros Netherlands Active Member Active Member
    108
    33
    City:
    Rotterdam
    State:
    Outside US / Canada
    -Return to Top-
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    In What category would this be? Mini, micro or nano workshop?
    Just 2m x 3m metric
    Verzonden vanaf mijn iPhone met Tapatalk Pro
  16. wrmiller
    1,011
    113
    City:
    Hereford
    State:
    Arizona
    -Return to Top-
    Thank you. The stupidest thing I ever did was sell that little SB1001 lathe in the background. I've been trying to buy it back ever since, but my friend won't even consider it.
    I may have to steal it... :cautious:
    Ken from ontario likes this.
  17. Fabrickator
    Fabrickator United States Active User Active Member
    342
    63
    City:
    Lakewood
    State:
    California
    -Return to Top-
    I got everyone beat on low end Mill stands. I have my LMS High-Torque on a cut-off piece of Formica counter top, sitting on the bed of my 60", cast iron, Oliver wood lathe. The Grizzly G0602 lathe is happily nested on a heavy duty base built between 2 oak, built-in storage closets.
    Ken from ontario and brino like this.
  18. DHarris
    53
    18
    City:
    Rohnert Park
    State:
    California
    -Return to Top-
    Zathros - your "shop" looks like it's in a very small / tight space - and you've made full use of every square inch!
  19. brino
    brino Active User H-M Supporter-Premium
    2,298
    113
    City:
    Almonte
    State:
    Ontario
    -Return to Top-
    I would say "closet size", but still a few steps above the "pocket size" workshop.
    By the way, due to the way you posted your pictures, they appear as simple red X's inline when using a web browser on a Win7 PC. I had to use a little trick to see them.
    When using tap-a-talk there is a special way to post them so everyone can see them. Here's a link:
    http://www.hobby-machinist.com/threads/how-to-post-photos-from-tap-a-talk.55947/
    -brino
    Zathros and RandyM like this.
  20. Zathros
    108
    33
    City:
    Rotterdam
    State:
    Outside US / Canada
    -Return to Top-
    Stand corrected,
    Its Tiny but got almost all, large tools like ciculair saw table etc is in another storage.
    Well all I can say it's dutch way of saving valueble space.
    Hope they're visable now.
    Grts.
    T.
    Btw, i've got à IT space like this on the 1st Floor also. Now the kids are gone have more fragmented. Backroom is the bicycle studio. And My terestial telescope travels from room to room.
    brino and Tozguy like this.
  21. Tozguy
    Tozguy Active User H-M Supporter-Premium
    802
    113
    City:
    Drummondville
    State:
    Province du Quebec
    -Return to Top-
    Zathros likes this.
  22. Zathros
    108
    33
    City:
    Rotterdam
    State:
    Outside US / Canada
    -Return to Top-
    Actually it's about 7 m below sea level.
  23. DHarris
    53
    18
    City:
    Rohnert Park
    State:
    California
    -Return to Top-
    Hoi Zathros, I have a friend who lives & works in Middleburg (we worked for the same company) and have traveled there a number of times. On one trip he took me to the "highest point" in Zeeland - it was on a bridge - don't remember the name or what it was over - - and was never really sure that he wasn't just pulling my leg. Truly beautiful country and people - some of the best of both I've had the good fortune to be associated with.
    dave
    Zathros likes this.
  24. ferlum
    ferlum United States Active Member Active Member
    53
    18
    City:
    Phoenix
    State:
    Arizona
    -Return to Top-
    Here's my work space. I have entirely too much crap stuffed along one wall of a two-car garage. Believe it or not, I still get two cars in here too.
    [​IMG]
    xman_charl, rdean and Zathros like this.
  25. george wilson
    george wilson United States Global Moderator Staff Member H-M Supporter-Premium
    739
    113
    City:
    Williamsburg
    State:
    Virginia
    -Return to Top-
    Bambam-That is the most complicated mini lathe I have ever seen !!!:) Do you also have a larger lathe to fit in with that Bridgeport mill?
  26. Rockytime
    Rockytime United States Active User H-M Supporter-Premium
    100
    43
    City:
    Arvada
    State:
    Colorado
    -Return to Top-
    Here is mine. First photo is a Grizzly G0781 mini-mill on a watchmaker's bench, next is my Sherline bench which started out years ago as a railroad modeling bench. Last is my MaxiMat7 lathe.
  27. Bamban
    319
    63
    City:
    Austin
    State:
    Texas
    -Return to Top-
    It is a complicated 9x20 lathe, I do have larger ones, lol....
    brino likes this.
  28. crossthread
    crossthread United States Iron Registered Member
    2
    1
    City:
    Dunlap
    State:
    Illinois
    -Return to Top-
    I picked up a Husky roll around work bench like the ones pictured in the first few posts. It's a good stand for my 7 x 14 Grizzly lathe. It's not as heavy as a Snap On toolbox, but it works well enough and doesn't cost a fortune.
  29. Moper361
    Moper361 Japan Iron Registered Member
    22
    3
    City:
    Chiang Mai
    State:
    Outside US / Canada
    -Return to Top-
    Hi I'm new here and just finding my way around the sight .Here are a few snaps of my hobby room here in Thailand. Not perfect by any means but keeps my days occupied .
    Regards Moper I 20170916_074257.jpg 20170916_074309.jpg 20170916_074313.jpg 20170916_074316.jpg 20170916_074238.jpg
    brino, DAT510 and Charles Spencer like this.
  30. DAT510
    110
    43
    City:
    San Mateo
    State:
    California
    -Return to Top-
    Welcome to HM Moper. Nice shop.
Share This Page
