- Apr 14, 2014
- 3,169
These are the 2 most common tools used to dress aluminum oxide grinding wheels. When using the wheels to create or touch up lathe tools the job is much easier with a truly flat face and square edge.
I use the first style almost exclusively, mainly because somewhere along the way I picked up a huge supply of replacement disks. Having said that I rarely use the grinder for making or sharpening HSS tools. I use a Rockwell Delta 6 x 48 sander. I use either 60 or 80 grit for initial tool forming and 100 or 120 grit for touch ups.
Cutter Type Grinding Wheel Dressers - -
www.msdiscounttool.com
POWERTEC Diamond Grinding Wheel Dresser for Bench Grinder 71003 - The Home Depot
The POWERTEC 71003 Diamond Grinding Wheel Dresser (36 grit diamond chips) dresses your grinding wheels to perfection. This handy and hardworking accessory is designed to restore your grinding wheels back
www.homedepot.com
