Yeah, I was thinking lead screws as in screws that drive movement (compound and cross) compared to feed screws for threading. The Atlas has one screw for both purposes on the carriage, except the carriage is moved by the handwheel and fed by the feed screw... but it's also a lead screw because the names are somewhat interchangeable depending on who you ask and how many drinks they've had. So disregard anything I said about lead screws, none of that will apply to your feed screw. If you buy the correct threaded rod for your needs, you can still work the ends of the rod as needed on your lathe because the spindle is hollow. Custom precision Acme rod is available for an attainable price in the US. I feel your pain on shipping, I lived overseas for 10 years and had hobbies then, too.
