Lead Paint on vintage Machine Tools
My wife is an environmental scientist, and studied, and wrote much of the work on the effects of lead paint on children for the NIH, and it affects a lot more kids than you would think, and the results are irreversible, and not pretty. Certainly not something someone would wish on any child. Don't work with it much now, but when I was a teen I did a fair amount lead and oakum joints on cast iron. Always enjoyed the process, just something intriguing about wacthing molten metal flowing. Mike
There is a "something" about molten metal. I spent years (5+) in a foundry (electrician) watching the casting process. With cast iron or steel, there is the "glowing" that leaded joints don't have. Lead is quite dangeruos though, it can't be sweated on among other things. Sweat will cause a blow up. When you sweat on iron or steel, it just fizzles. Lead blows up. Curious. . .
I wonder what pipe large commercial union projects use in New York/ Chicago areas.
When I was at the "Pipe Shop", the bell end of the pipe was cast with internal grooves for a "Tyton" seal. (Reg? U.S.Pipe) A "rubbber" seal, probably neoprene or some such. I never actually saw it used, but was told is was a "slip joint" arrangement. The pipe in the ground has the spigot end exposed. The pipe section going in has the seal installed and lubricated. It is then slid into place. There is also a bolted flange joint that uses a sort of "O" ring seal. We made a large order for Saudi Arabia back when. Some was the Tyton joint, some had bolted flanges. I don't remember much about the Tyton joint, just that the label was printed on in the paint line. The seals were made in a different plant, as were the screw on flanges.
When I worked at the N. Birmingham plant, we made from 6 inch to 13 inch. Soil pipe, sewer pipe, of 4 inch and smaller was made at Anniston, and large pipe, up to 60 inch (5 ft) was made at the Bessemer plant. That was 40 years ago, today the N Bham plant is an empty field. Probably an EPA site. Presumably the Bessemer plant is still operating.
Birmingham (Ala) was a cast iron center in years gone by. Most of the shops, pipe and otherwise, are long gone. There are also the ACIPCO and I think McWane pipe shops. The EPA and economics have shut down the rest. Probably to China. . .
We transitioned to the rubber seals on cast iron sometime in the later part of the 60's. Had a special tool made by Rigid I believe, to pull the sections together. Still have the rigid cast pipe cutter we used back then. Reclaimed it from my dad's shop during the estate sale. Mike
Pipe puller. All my experience is gasket joint but there were some lead joint jobs around when I started in the 80's.
