- Sep 1, 2023
- 489
I only found out about the expanded product line myself a few weeks ago.Well, thank you for that. Nothing like facts to foul up a good argument!
Took me a second, wrong line.Really 1/10th. I would think that the scribe was the difference.
Best of both worlds, I use these and fill them with Dykem blue layout fluid..... I have never had one fail or dry out.I scribe everything and cut to the line. Old school operations, as I exclusively use handwheels.
Yes, I'm a luddite...
I interchange layout fluid and sharpie. Has depended on if the surface is horizontal or vertical.
Am getting really low on layout fluid and am thinking of moving to sharpie only.
Am curious about your thoughts on the topic.
Note: I value the thoughts of veteran machinists (both handwheel and DRO users) as well as those new to machining.
What are your thoughts and experiences.?
Daryl
MN
I find that using a felt pen makes for more precise scribe lines than layout dye, which sometimes tends to flake off when scribing, for large areas of layout, layout dye is clearly the best choice, I find that layout dye tends to take on water, which degrades it and makes it take longer to dry, I use Dykem blue, but prefer Starrett layout dye as it is not so strong smelling as Dykem.
I like that smell. It smells like model airplane dope from when I was a kid and would use silk or silkspan. ahhh the memories.I find that using a felt pen makes for more precise scribe lines than layout dye, which sometimes tends to flake off when scribing, for large areas of layout, layout dye is clearly the best choice, I find that layout dye tends to take on water, which degrades it and makes it take longer to dry, I use Dykem blue, but prefer Starrett layout dye as it is not so strong smelling as Dykem.
