- Jan 28, 2022
- 850
Hi, I made this adjustable work stop as an aid when doing work. The stop is inserted completely assembled, then secured with a pin into the spindle. With the thumbscrew you can set the stop to the desired depth needed. I removed the gear cover only to show how the pin locks into the spindle. There is now need to remove the cover to install the stop assembly. When the stop is retracted the chuck functions normally with no need to remove the stop from the spindle. I am working on a cover to shield the unit when in use. I also am making different sized adaptors for more conditions as shown in the last photo. Thank's for looking.
