Hi, I got my first lathe and am just getting into the hobby. The thing is my lathe doesn't have any oil ports for the spindle bearings and i'm not sure how it gets lubricated. I opened the top up to find grease on the bearing that look dried up. I'm not sure if these are sealed angular contact bearing or normal taper bearing, if they are sealed angular bearings then I would expect it to be greased. The lathe I have i'm not exactly sure what it is, I only found out by asking you guys on this site (which is amazing) and it seems to be close to this lathe just without the milling attachment: https://smithy.com/sites/default/files/media/pdf/MI-1220 Manual 2010.pdf
This manual doesn't talk about lubricating the spindle bearings in anyway so that's why I'm here.
If you guys need a picture to help I can get some of the bearings, or at least what I can see from taking the top of. I don't want to have to take apart the spindle to re grease the bearings or anything like that because I don't know how. Thanks a lot.
