- Jun 30, 2015
- 10
Is any 10W oil suitable for use on/in my Atlas TH48 lathe? Can supertech power steering fluid be trusted for use on lathe?
You're right, Andre. No sump for the Atlas lathes, but the drive shaft ball bearings are sealed, so might present a closed system. The Atlas Tech Bulletin #12, Lathe Lubrication in the Downloads section specifies SAE 20 wt. and does not specify not to use detergent oil:Do Atlas TH46's have oil sumps or are total loss systems? If total loss I'd imagine any metal particles from your bearings (which should be microscopic) would just run out.
http://www.hobby-machinist.com/resources/atlas-tech-bulletin-12-late-lube-chart-pdf.2926/
Here's what it says though in the SB How to Run a Lathe: ...be certain that machine oil is used, not automobile engine oil.
