- Nov 9, 2015
- 407
what is your take on internal threading? DIY? purchase?
- if DIY - how did you make it - got any pictures to show for it? any tips or things you'd do differently?
- if purchases - which one are you using ? what is it's benefits (insert type and whatnot)?
I use bars that accept HSS ground bits, like Tom shows, as well as tool holders for threading inserts.
For small diameter bores, I have a 1/4" bar and a 5/16" bar. I grind the bits from either round or square HSS blanks.
For larger diameter bores, I have 8, 10, and 12mm bars that take an 11mm IC insert, an a 16mm and 5/8" bar that take a 16mm IC insert.
I prefer the inserts simply because they are easier to use and seem to stay sharp forever. I use the HSS bits for smaller diameter bores.
Here is a pic that shows the 8mm bar with the 11IC insert and the 5/8" bar with the 16IC insert. It also shows the 1/4" bar with a bit ground for ACME threads and the 5/16" bar with a bit ground for 60 deg threads.
