Lathe Dog Questions
My 'new' lathe was made in 1943 in Sweden. It came with a drive plate with a pin protruding from it. The dogs are straight pin type.
Everything old is new again.
Here is a pic of a simple drive dog I made for my mini lathe
Make your own using the suggestions here or use shaft collars and either weld a stud on or drill and tap or use a bolt and nut for the stud. Cheaper than buying "real" dogs.
definitely make before you start stocking up on them. You might find you use them less often than you thought. I almost always come up with other ways to drive stuff, like holding one end in a 4 jaw chuck. If it's worth setting up with a dog so I can remove and replace a couple of times, then it's probably worth my time to make a quick dog for it.
I often find the pre-built dogs don't fit in the setups I want to use them in anyway. Like the bent one doesn't fit when I want to use my chuck, and turn a center in a bit of stock held in the chuck. I wanted a dog to place against the chuck jaw, but had to make a shorter one to fit.
