- Jul 30, 2017
- 475
It's been said before but it bears reiterating. The critical dimension when deciding on a QCTP is not the swing of the lathe but the distance from the top of the compound to the spindle centerline. This is the minimum height that a tool mounted in a tool holder can be and still hit the centerline. I measure this height by mounting a pin of known diameter in the chuck and either measure the separation between the pin and the compound and adding half the diameter of the pin. For my Grizzly G0602, that distance is .924". Unfortunately, this information is not provided in machine specs so when buying a new lathe, one must either go on other's experience or wait until you have access to the lathe for an actual measurement before purchasing a QCTP.
One can always use smaller tools than the tool holder will accept. I prefer to use 3/8" brazed carbide or HSS tooling in my AXA tool holders so I don't have a problem with the minimum height restriction. How3ever, if your choice is insert tooling, you have to be able to accommodate the tool shank. 1/2" insert tools won't work with my lathe and most AXA tool holders, the exception being the AXA-XL holders. However, 12mm insert tooling will.
On a final note, the B dimension in post #2 above varies even in tool holders from the same manufacturer. The clue is that the specified dimensions are given in fractional inches rather than decimal inches. There has also been some indication that the spindle centerline to compound distance can vary for lathes of the same brand and model depending upon year of manufacture.
All good info, thanks gentlemen.The Dorian catalog has a section on sizing and includes a worksheet for determining the best tool post size for your needs. Dorian is easy to translate to Aloris sizes too.
Too big to upload today at 8 megs? I thought the limit was 30.
Here's a link.
while reading a bunch of post I noticed on Davidpbests chart there is a large variation between the Aloris and Dorian TP height...
Just would be nice to have a chart of tool posts that work well on a particular model lathe where you can see that a Dorian AXA fits better than Aloris or visa versa.
