- Jun 29, 2014
- 4,063
Great write up, Cobra. You do some nice work!
In your shots it looks like that broach face is 90 deg to the cut with a little bit of relief ground on the contact face? Is there a rule of thumb for grinding these?
I have ground mine at about 7 deg. I haven't yet made the cut. Maybe later this afternoon if I have time.
I hope it works as well as yours did....
I also have only about an hour a day most days to devote to my hobby, so my learning process is pretty slow at this time....
There is a demonstration of it in the book "Tool Steel Simplified", they have heat treated and soft steel clamped on one end, and hang equal weights on both, and they deflect equally until the elastic limit is reached, and the soft steel takes a permanent set (bent). This is why a hard boring bar is no stiffer than a soft one.Ben, the boring bar method is actually my plan B with a single tooth cutter, as to me grinding the cutter seems an easier solution based on my meager shop. Until I get the drill\mill thing running again I am quite challenged in drilling holes for a boring bar. I am hoping to change that soon though.
I'll have to take your word on what you just said as understanding the modulus of elasticity is way outside of my wheelhouse.
Its hard to believe that HSS and tool steel have the same flexability cuz in my hand tool steel just feels harder\stiffer. I realize that isn't any reliable test, but just my feel for it.
I'll gladly soak up any shreds of wisdom anyone wants to share though.
Is there a way to briefly describe what that is for me?
A friend of mine has done a bit of this. His advice was if your lathe is small/light(9"SB) "pull" the cutter out, not pushed in towards the headstock.
