I recently bought a Logan 10” lathe, model 815 and I’ve been working on getting it setup. I’m puzzled by a problem I’ve run into.
I first leveled the lathe. Then I mounted a test bar between a center in the spindle and a center in the tailstock. Adjusted the tailstock till I got it cutting over a 10” length with less than 1/2 thousandths of a taper.
Then I mounted my chuck and cut a 60 degree center held in the jaws. I measured the chuck held freshly cut center and it had no detectable runout. Without taking that center out of the jaws i then mounted my test bar with a center in the tailstock. But this time i cut a taper! Bigger by 4 thousandths at the tailstock end. So I’m getting a big difference between when a center is in the spindle versus a fresh cut center in the chuck.
I’m puzzled ( and afraid) as to what could account for this.
I don’t think either bed wear or bed twist could cause the difference because it seems like both would affect the test the same. Wouldn’t matter how the center was being held in the lathe.
So is the likely problem that the spindle bore and the spindle threads aren’t concentric? Or, am I missing a different cause.
