Reading Docsmachine's blurb,I can see that if he had put his time into making real money,instead of fiddling with that crappiest of vises,he could have bought a REAL vise with the money.
He did a nice job of making it accurate,but he still has a vise made of window weight grade cast iron,full of blow holes and who knows what else the Chinese tossed in(like old ball bearings,anyone?) Such HAVE been found in Chinese steel,breaking expensive tooling,and causing much trouble in commercial shops unlucky to have purchased Chinese steel. That vise casting will never have the strength and integrity of a decent Kurt. I got mine slightly used for $275.00,and have loved it. I did have to (luckily) find a JAPANESE swivel base for it,that is THICK ENOUGH to resist lifting from the table under milling pressure). My former ones were Enco's bought back in the 70's,and probably made in Taiwan at that time.(They would lift,too!) They worked o.k.. But,I'd HATE to have to rely on the new stuff coming out of mainland China.
Whenever you look at vises,look at the BASES to make sure they are thick enough to resist lifting under MODERATE milling pressure. Most are just TOO THIN. Look at a picture of a Kurt base carefully,and compare them to the vise you are considering. That is at least,a judgement you CAN start to make just by looking at pictures.
There are,at least,a few brands that cost MORE than chinese low grade junk,but LESS than a real Kurt. I advise buying one of those if you don't want to pay for a Kurt. They might still be Asian,but are a better grade. You get what you pay for. The Chinese can do good work,IF you pay them to do so. So can the Indians. No one can afford to do good work for starvation wages.
