- Apr 23, 2018
- 6,531
Mike, for your two flute end mills, after you've ground away the broken bits and index the face to the helix, you need to cut big relief cuts in front of each cutting edge. Then cut your 5-deg cutting edge and clean up the clearance cut. It's a funny thing with two flutes, they don't work like 3+ flute EMs in that regard. Keep a good example on hand as you go, it'll help. Welcome to the club, and good start! Your tool budget will find wiggle room now that basic cutting tools can be reused until there's nothing left but a stub.
