- Jul 20, 2012
- 1,240
Consider switching the tightening screw around so you can adjust it from the front.
Interesting idea! I can't easily do that because the hole in the upper wing is only 3/8" diameter and there is not much room to go larger. The screw is 3/8-16 so....
R
Thanks Russ! It is much easier to check the pattern and follow the result.
