I was cutting a 3" exhaust pipe today and the blade sized up at the bottom of the cut, I switched it off withing a couple of seconds but after that no blade movement.
I opened up the gear box, the gear lube was gold colored and the brass/bronze worm gear is finished.
20 Teeth
I t looks like the easiest way to replace, would be to drill an access hole to punch the roll pin and then hopefully the worm gear will simple pop off the end?
Then thread the access hole and put in a plug with sealant.
Anyone do this repair?
Source for worm gear?
20 Teeth
