I was thinking to myself, what with all the old Bridgeport's, and clones out there that sell cheap,
I wonder if it would be possible to reduce the weight of one of them a significant amount?
The idea is to reduce the weight of each individual component so that when disassembled it could be moved into a basement or some area where you cant get a forklift or such.
The base/body is probably the single heaviest part, weighing I think about 800 lbs.
So I'm picturing making it look like a piece of swiss cheese. Cast iron drills quite easily (messy also), maybe even consider a 2" diameter hole saw. Or you could lay out a series of larger square holes, drill the corners for start holes, and use a saws all. The idea would be to cut the weight in half. In fact on some older models there is already a good sized door opening in one side.
Now I know there will be objections as to why the weight is necessary, but after looking at all the machines listed on Lathes.uk.co and seeing how we use them at work, I believe the main reason they are so heavy is simply so that they won't tip over when putting a large load on the table. ( I think they are rated for 500lbs, but I've seen heavier loads put on them) I have actually seen a rather large Moore jig grinder tipped over when someone had a large die shoe on it and cranked the load too far off center.
It's unlikely that anyone in a home shop would ever put anything over a hundred pounds on there machine.
The next heaviest part would I guess be the knee, I'm sure we could pare it down a little, and next would be the ram. Of course the Milling head (i'm thinking a 1 HP J head) would probably stay unchanged, as well as the table (maybe a 36" If you could be so lucky as to find one.
There is also an even older smaller "M head" but I don't think it has a boring feature built in.
It's not likely that I would actually attempt this, unless I found the machine I wanted close enough to home that I could spend multiple days working on the disassembly to bring it home in pieces, I guess it's more of a thought problem to work on. Maybe someone here has an even better Idea.
