- Nov 26, 2015
- 17
The last couple of months I've read every thread relating a vfd. Having a grizzly 10 x 20 lathe, I decided to change over to 3 phase one horse d80 frame ( exact replacement ) size motor and a KBMA adjustable frequency drive.
I have all of the parts here now, so I set it up on my backbench to test.
Adding to my materials list was 20 feet of 14/3 so wire and eight feet of 14/4 so cable. The 14/3 is for power from the outlet to the control box, and the 14/4 wire is to go between the motor and control box. Also used two 20 amp twist lock connectors to be used on the 3 phase, wiring (so I could remove the motor if I wanted to).
Wired it all up using a very good KBMA manual. On the bench, every thing works good.
The manual does not mention a breaking resistor.
My question to anyone who might know about my setup, and adding a breaking resistor. Really don't know even if I need the quick breaking system except for 1. An emergency stop and 2. to assist in thread making.
Thanks in advance for any help.
By the way my background is putting out fires, and electrician.
