After lurking here and on other forums for some time I ordered and received my g0704 mill. Since this is my first mill and first time machining I want to say thanks for the wealth of info and friendly help found here.
I broke it down for a thorough cleaning and I'm in the process of tramming it and have some questions.
I see that Mobil Vactra #2 and #3 are recommended for the horiz and vert ways. What type of grease is recommended for the screws? I currently have some white lithium grease on them after stripping off the shipping grease that came on them.
After getting some experience with it I plan on converting it to CNC. I have a set of 2 and 4 flute imported end mills I have been practicing with but what is recommended as far as better quality versions. I will mostly be cutting aluminum and believe that USA made HSS are well regarded for that. What brand or source should I look at?
For finishing passes on aluminum, especially on larger flats, are fly cutters or face mills preferred over end mills? If so what types and brands?
Thanks again.
Thanks again.
