- Jan 2, 2019
- 6,526
Surprisingly enough many machine tools have switches that require you to reach over the rotating bits to turn them on/off. I’m not really sure why that is, maybe to remind you to be careful when using them?Okay so I've got the lathe back together only thing is missing is the motor which I'm currently trying to work that out because I'm trying to add an extension to the switch I'm trying to add an extension so I can add a power switch to the motor that way I'm not having to reach behind the lathe to turn it on and off but when I add the motor wires in I always seem to get continuity or a short and the switch does nothing...
Anyway, you should set your machine up in a way that you’ll be comfortable and safe. Post some pictures of what you’re doing and I’m sure one of us can help you get it wired correctly.
John
