- Jul 30, 2017
- 476
Hello sir...Not sure where and how exactly the bolt pattern varies, but you could add 6" a spacer into the center structure and/or add a plate to the top of the pedestals to address the different bolt patterns.
Yes it would require a new cover plate for the center but you could also build it out so that it is a storage cabinet or shelf in the plate to use that space. You already have the stand. If you buy a new one, you will have two and what good would that be to you.
If my stand was close in size I'd use it, Its off enough to not be worth while, Its going with the lathe, just hope its appreciated.
Its really is a weird predicament I'm in, It would be a pain to fully rebuild the center section and drawer to fit the new lathe which also has 9 more inches of depth too... the chip pan of this lathe is 59.5 X 19.5 and the new lathe is 66 X 29 per PM website.
I think at this point It might be easier to get a stand with the new lathe to save valuable time, and later on down the road turn the new stand into a project after a few other projects have been cleared away.
Thank you for your input though...
