- Nov 25, 2015
- 8,313
did you check the top bearing in the sander?
edit: also did you check the belt tension? maybe too tight?
I was using the wire wheel when it was acting up, so I removed the belt to free up some power. The fault continued, so that eliminated that possibility. I just have to come to terms with tearing into it even though I have more important projects to work on right now. I sure don't want to be without it while I'm doing fab and auto resto work. I'll post what I find on Friday or Saturday. Thanks to all for the assists.did you check the top bearing in the sander?
I have a Jet grinder. I have the same issue of getting SUPER hot. I can't touch it when I have been using it a long time. I did stop it from climbing non-stop, but it still gets too hot.I was using the wire wheel when it was acting up, so I removed the belt to free up some power. The fault continued, so that eliminated that possibility. I just have to come to terms with tearing into it even though I have more important projects to work on right now. I sure don't want to be without it while I'm doing fab and auto resto work. I'll post what I find on Friday or Saturday. Thanks to all for the assists.
Projects begat projectsI was using the wire wheel when it was acting up, so I removed the belt to free up some power. The fault continued, so that eliminated that possibility. I just have to come to terms with tearing into it even though I have more important projects to work on right now. I sure don't want to be without it while I'm doing fab and auto resto work. I'll post what I find on Friday or Saturday. Thanks to all for the assists.
