- Sep 26, 2013
- 408
I broke the spindle switch on my early 80s Jet 1236(don't ask how). As a result the lathe won't run, not sure why but it was up and running before this unfortunate accident. I pulled back the spindle rod off the switch, that didn't happen when I screwed up.
All the wires are still connected so that dashed my hopes of an easy fix. I
Will any standard 3 position rotary switch work? I did a google search and there are hundreds types/sizes, this would probably be the better option for a quality switch, but don't know what to buy.
Here is a spindle switch (the "new model" micro switch for grizz lathes) I can order(I think) from Grizzley, will it work? I realize its not exactly the same physically but I can work around that, I just need it to have the same switching capabilities.
thanks, Brian
edit: just saw this thread a few posts down from mine, sorry for the redundancy.
http://www.hobby-machinist.com/threads/need-help-with-a-lathe-power-switchswitch.40614/
The switch on my lathe does not power it on, the guy I bought it from had it wired to an on/off switch in the power cord, so this switch is/was used only to reverse feed direction. This switch is suggested in that thread(above), will it work for me, running 220@15amps?
thanks, Brian
