- Jun 12, 2014
- 4,811
Agree with Bob Korves on trying to use the any runout between the arbor and the chuck to cancel out each other (or consider a keyless chuck with an integrated arbor). I recently had a Jacobs 14N which I bought used, but was in very good condition. I was surprised that it had a TIR of 0.005". I took off some high points on the jaws, and then milled a wedge tool out of some 1/2" aluminum. Took some effort, but was able to separate the chuck and the arbor without any damage. Put the arbor in the lathe and used some very fine grit sandpaper to clean the mating surfaces, then put the arbor in a 4J independent chuck and zeroed the runout. I put some 1/2" precision rod in the Jacobs chuck and hand mounted it to the JT3 arbor. I then kept indexing the Jacobs chuck to the arbor until I got the lowest TIR from the precision ground rod, the TIR was now 0.0005". When I pressed them together and mounted in my mill, the TIR was~ 0.0008" with 1/4 and 1/2" rod. Although you can measure the drill chuck and arbor separately and estimate what might give the least TIR, that did not give the lowest TIR, most likely because of slight difference in taper and the interference fit. Only by indexing the two, and measuring them together at difference points, was I able to get the minimum TIR with both pieces joined.
As others have mentioned, using a short stiff center drill to locate the hole really helps in decreasing the drill from walking. Using shorter screw machine drills with 135 degree flutes helps, a lot also depends on the material and final size hole. I usually use an end mill to finish a larger hole after stepping the hole larger with standard drills. As of recently, I have had issues with end mill bits causing over sized holes in some materials, because they do not clear the chips as effectively as a good sharp twist drill. Good lubricant and clearing the chips is important. You may use a chuck reamer if you need a high degree of accuracy or slightly over or under size diameter. I find that an ER-32 collet holder to have the least run out in my mill, and after that, a keyless drill chuck with an integrated arbor. There are also factors of how well your mill is aligned and rigidity.
