- Jan 7, 2016
- 13
Hello,
I recently picked up Rusnok Model 70 head and I believe the motor was damaged in shipping. Buzz sound when trying to start it so I cleaned the starter contact. I then noticed a crease in the housing and gently tapped it out and it will pull start when wrapping shaft with string but then freezes up after 10 seconds or so. Magnet pieces fell out when cleaning the contact so I assume it’s toast. Anyway I’m looking for an easy swap. The data plate has the frame as a 56-2, but I cannot find that exact frame for sale. Will a 56c work? Mounting bolt hole is 3” center of shaft to bolt hole (might need to verify that) 4 mounting bolts are 4” apart in a square formation. The motor is reversible with a switch mounted on it. If some of you have a better upgrade, I’m all ears. Please see picture. Thanks!
