- Jan 22, 2011
- 8,031
That sleeve is known as a coupling sub, and normally is RH thread on both ends. No need to confuse the roughnecks. There are various drill string components that use this thread, up to and including the bit itself.
You're right about component 34. This whole thread is complicated to cut because you are making up at torque on more than a single element, as on a standard RSC. Even those you are making up on a tapered thread and a shoulder at the same time.
