    Dismiss Notice
Is this motor suitable for a VFD?
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by Ropata, Sep 4, 2017.
  1. Ropata
    Ropata New Zealand Active Member Active Member
    23
    8
    City:
    Wellington
    State:
    Outside US / Canada
    -Return to Top-
    Hi guys,
    Is this motor capable of being run off a VFD?
    I seem to remember 2 speed motors being a bit troublesome.
  2. markba633csi
    markba633csi United States Active Member Active Member
    402
    83
    City:
    Mountain View
    State:
    California
    -Return to Top-
    I think the 400 volt requirement will be the difficulty, although I have heard of people using step-up 3 phase transformers on the output
    of a 230 volt VFD but it tends to be an expensive solution unless you get the transformer cheap or free.
    Check the cost of rewinding the motor to a lower voltage vs replacing the motor with a lower voltage one.
    Mark
    ps if your motor is a "star" winding you can power it from a 230 volt 3 phase source (or VFD) directly but if it is a "delta" type winding you would need a step-up also.
  3. Ropata
    23
    8
    City:
    Wellington
    State:
    Outside US / Canada
    -Return to Top-
    I have my eye on a VFD with 240v input to 400v output such as the 1hp gs2 model from automation direct.
    Sent from my SM-N920P using Tapatalk
  4. markba633csi
    402
    83
    City:
    Mountain View
    State:
    California
    -Return to Top-
    That sounds like a good solution, I wasn't sure if something like that was available
    Mark
    ps I checked their website and couldn't find a model like that- can you post the model #?
    M
  5. Ropata
    23
    8
    City:
    Wellington
    State:
    Outside US / Canada
    -Return to Top-
    Pretty sure this will do the trick. Only thing I'm not sure of is the 2 speed motor and how it would work.
  6. mksj
    mksj Active User H-M Supporter-Premium
    1,435
    113
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    The GS2 VFD will not step up the voltage from 230 to 400V, there are only a few VFDs that I am aware of that are capable of this and they are available through a UK vendor (link below). The usual setup is using a step-up transformer and a 400V series VFD (some can handle a range of output voltages, so something like the WJ200-007HF is rated for 380-480V). The problem you will run into is the VFD is only rated for 3 phase input in this voltage range, so if run off of single phase you would need to run it off of a WJ200-015HF (usually a 3 phase input VFD needs to be ~1.7X if run off of single phase). Otherwise you can go from a RPC to a step-up transformer to your 3 phase input VFD with no derating.
    http://www.drivesdirect.co.uk/how_to_choose.htm
    I have not had much success with 2 speed motors and VFDs, they seemed not to perform as well in particular on the lower pole (high speed) setting. I have also setup switch gear and VFD programming to be able to switch the VFD settings and motor connections between both speeds, but it is complicated. I would use the higher pole setting and over-speed the motor to 120Hz. Also, I believe this is a constant Hp motor, so they may behave differently, but I just dealt with one used on a mill and we went with the low speed (higher pole) setting and adjusted the output Hz to over-speed the motor. You can try one or the other and see which works best with your VFD.
  7. killswitch505
    killswitch505 United States H-M Supporter - Premium Content H-M Supporter-Premium
    80
    28
    City:
    Hobbs
    State:
    New Mexico
    -Return to Top-
    Yep that's a go with the gs2 I've used them on a lot different applications they're a great drive. I would really consider a new drive rated motor and GS2. Side note none drive rated motors have a had time keeping cool at lower frequencies. I'm not sure what your budget is but it's only money and you can't take it with you when you're gone.
Share This Page
