- Dec 18, 2019
- 6,458
I've done ok with Rock Auto for some things, but not Subaru brake pads or rotors. Lets just say the rotors and pads aren't quite OEM quality, nor are the simple little things there, that you may need, like properly sized threaded holes in the right places, should you need to jack off the rotor. Yeah, that was fun, hammering off a stuck rotor.Thanks a lot will definitely use them. For rockauto I had good experience but with parts from ram1500 did not use it for Subaru my friend who had one told me to get only Subaru parts from Subaru. I found the 50$ each but was from autozone
$60 for an OEM rotor vs $50 for a suspect rotor, I'm going to take the OEM every time. Because that $50 part won't quite fit and will cost you at least $10 in labor and aggravation to get it to work.
