- Oct 31, 2015
- 469
I thought I would share this app that I discovered today. Its called Video Tachometer, and that's exactly what it is. It uses the phone's camera and measures rotational speed by altering the frame rate - you adjust the frame rate manually and when the image stops moving, you have the speed. It measures in Hertz or RPMs. The free version has a 10 RPM resolution and the paid version has a 1 RPM resolution. I used the free version today to check the speed of a centrifuge and it worked great. It works for iPhone 5s and newer.
