- Feb 14, 2020
- 166
Hello,
I'm rebuilding a Jet 1340 lathe and wanted to replace the single phase 3hp motor with a three phase motor and VFD control. Primarily because the circuitry in the lathe's cabinet was toast and I didn't know how to fix it. At the time, contactors, overloads, relays, and all that jazz had me confused. I'm now more confident in that regard, but I still like the VFD and 3-phase over single phase/single speed. Probably a little overkill, but I purchased a 5 1/2 HP Marathon motor with a 112M frame (same frame as what came off my Taiwan-made JET 1340), inverter rated for continuous duty. Since I invested in a nice motor, I decided to invest in a nice VFD as well.
I purchased the Invertek Optidrive E3. I had very little experience with VFDs and no experience using low voltage control circuits. Everything I had done was on the VFD's control panel. The manual was still a little overwhelming, but I was able to get the motor up and running. From there, I was a little out of my league.
Here's the reason I'm writing this post. 888-862-5659. That's the technical support for Invertek. I have no way of expressing how F*#$ING amazing these guys are. Specifically a guy named Matt. There was no ticking meter and the feeling of being rushed. He wanted to know the intimate details of my application to make the drive work for me how I wanted it to work. He was as much an educator as he was a technical resource. Making sure I understood the concepts of advanced motor control using their VFD so I could apply those concepts to the information contained in the charts within their manual. Basically he taught me to fish instead of giving me a fish. I went from knowing virtually nothing about the capability of a VFD (beyond changing single phase to 3 phase) to doing some rather advanced wiring on my lathe. This includes:
So, this post has gotten really long, but I felt folks may have a greater appreciation for the support I received when going from VFD-dumb to where I am now using Invertek's free support. The long and short of it is, if you're in the market for a drive and don't mind paying a little more than the generic Chinesium drives on Amazon, and this is your first rodeo, you might be wise to get an Invertek and call Matt for some help.
- Integrating all the existing safety limit switches and applying a fast-stop command if they're tripped during operation (opening panels that shouldn't be opened during operation). This includes lock-out until the condition is rectified (ie. cant start the lathe if I opened the change gear door until I close it). Chuck goes from 1800 RPM to 0 in less than a second.
- Integrating limit switches for apron forward/reverse control, subject to lockouts. Won't work if any Normally Closed safety limit switch is opened.
- Integrating limit switch for brake control with DC Injection Braking. No more brake pad running on a motor pulley journal. I put a little pressure on the brake pedal, a lobe on the shaft closes a limit switch, and the chuck stops in about 3 seconds. I put the pedal to the metal and the shaft's second cam engages a second limit switch and initiates a fast-stop, which brings the chuck to a dead stop in less than a second. I haven't done enough research on the effects on the headstock gearing when I bring the lathe from full speed to dead stop that quickly. Until I do my research on the wear/tear of that action, I'll only use fast-stop when it's necessary. If I find that there's virtually no impact on the health of the gears using fast-stop, I'll probably just switch to always fast-stopping.
- Low voltage switches have replaced the old high-voltage switches that were crusty and decaying.
- I have 2x 30mm illuminated push button latching switches that now control: flood coolant on/off, lathe lights (2 overhead, 1 snake light) on/off.
- 1x 22mm keyed switch. This runs to a contactor that interrupts the 3 legs of power between the VFD and the motor. When key is inserted and turned to on, contactor coil is engaged and power can pass from VFD to Motor. When not in use, key is removed and tucked away where curious kids can't find it.
- 1x 22mm 10k Potentiometer to control lathe speed. I will be installing a tachometer soon.
- I have 1 original hole remaining with a 30mm illuminated latching push button....not sure what I'll use it for....maybe to turn on my TV?
