- Dec 26, 2015
- 2,080
Perhaps we should take this off thread to a DM?
As I suspected, the Sherline indexable tooolholder is proprietary and doesn’t conform to industry specs. Good thing the test insert was $8.00. Now you know. Lets take this to another thread please.Here is another photo. This shows the holders and inserts from the underside. The experimental insert is on the right side.
The experimental insert DCGT overhangs the tool holder more than the Sherline insert DPMT. I think that the extra overhang is due to experimental insert having a smaller clearance angle: 7° versus 11°. The inserts are the same size (0.25-inch inscribed circle) on top and have the same thickness (3/32-inch). The smaller clearance angle gives the experimental insert a larger underside. I conclude that the experimental insert does not fit the tool holder well.
whatever you folks do plez STAY AWAY FROM SCAMAZON!!So, I hope I can do this here and it doesn't come across as an advertisement. As many of you know, one of our members, David P Best, has been toiling over a book that he intends to publish. It is titled "Introduction to Indexable Tooling for the Metal Lathe: A User Guide Paperback" . He has completed it and it is available to order from Amazon. I know that David does very fine work, and I would anticipate that this book will be no less of an example of his capability.
I ordered mine last night. Should be here next week. Really looking forward to it.
Introduction to Indexable Tooling for the Metal Lathe: A User Guide: Best, David P.: 9798753874993: Amazon.com: Books
Introduction to Indexable Tooling for the Metal Lathe: A User Guide [Best, David P.] on Amazon.com. *FREE* shipping on qualifying offers. Introduction to Indexable Tooling for the Metal Lathe: A User Guidewww.amazon.com
Reason for Edit: Updated the Amazon link.
Kinda hard since that's the only way to get this book that I know of.whatever you folks do plez STAY AWAY FROM SCAMAZON!!
This is true. Amazon is my publisher and does the fulfillment. They accept returns and will exchange damaged items.Kinda hard since that's the only way to get this book that I know of.
Why so fast?The DCGT 21.5VFR-J10 J740 insert arrived. I installed it on the right handed tool holder, and used it to turn down 1144 steel and a bronze-aluminum bushing. Here are photos that compare the DCGT insert on the right-handed tool holder and the Sherline DPMT insert on the left-handed tool holder. In the photos, the left-handed tool holder is on the left.View attachment 393149
Note: I damaged the tip on the trial insert. The nose radius was 0.001 inch. The finish was poor during the finishing pass (2500 rpm spindle, 0.0003 inch / spindle revolution, 0.0005 depth of cut.) on two 1 1/8-inch diameter bronze-aluminum bushings.
