Interrupted cut on the back gear, should it be done?
I've been using an ML7 on the back gear to do facing off operations and will certainly be using it for other interrupted cuts in future. The problem is that when I'm performing any kind of interrupted cut on the back gear there's a troubling CLACK from the back gears as they re-engage when the workpiece engages with the tool. Is that something I should be worried about? Should I be avoiding interrupted cuts on the back gear?
The bearings which I'm still in the process of getting right could be part of the problem. I've found the previous owner of the machine lost/discarded some of the shims in the plain bearings and the amount that I tighten down the tops of the bearings can tighten the spindle so much that it can't be turned by hand, so I've made some home-made shims which prevent that effect and make sure the spindle runs very freely in the bearings with little play (under .001"). Could the looseness be a factor in allowing the gears to become disengaged in the first place? There's a lot of momentum even in just the small chuck so it seems reasonable that the spindle, chuck, and workpiece could spin round freely and pull away from the teeth on the back gear. I also find that a bit of resistance in the system, a hand on the smooth surface of the chuck, means the gears never disengage and the clack goes away, but I don't know if there's still enough impact to damage or wear the teeth on the back gear prematurely.
Maybe the white metal bearings should be tight enough to introduce that resistance themselves? Maybe the resistance should or could come from somewhere else?
Any experience or ideas appreciated. Thanks.
