I am about to try internal threading for the first time. I have several questions. Here is a 1st "box" I made that has a good suction fit on the brass lid to bronze base. It is a small box, about 1.5" diameter and the base is about 1.25 high. See photos of box and interior of base. The next box I am in process of making is 2" diameter aluminum and will be bored to about 1.75 diameter. I want to thread the lid and base on this one.
My lathe has a screw on 1 1/2-8 spindle, so I don't think I can safely thread toward the tailstock. I want to make a very fine thread so as to slow down the feed. I also intend to use the backgear to slow the rpm to about 90. I have Machinery's Handbook (19th), and I cannot find the dimensions for a very fine thread. The finest thread I can find is 1 3/4-20. I am also trying to keep the thread length at a minimum (around 3-4 threads). Obviously, I don't want to crash the lathe into the shoulder of the box.
Not sure how to calculate the dimensions. As stated above, this is my 1st attempt to do internal threading. Tips and suggestions would be appreciated.
