I just received a 140 servo power feed to be used on the x axis of my Clausing 8520. Surely someone out there has or has posted drawings of the installation. It does bolt right in without the bracket but needs something to hold the brass gear in and a bushing to go from the threaded rod to the roller bearings. That is the easy part. how do you adapt the drive to the splined Bridgeport inside of the Brass gear and can you extend the threaded shaft to remount the handle and maybe the round dial? HELP, HELP
