- Apr 29, 2019
- 2,071
I think the interval depends on your water quality. I have city water and drain and rinse mine once a year. I always get some sediment out of it.
My process is to first turn off the inlet and outlet valves where they are connected.
I then open the drain and the over temp valve to drain the tank.
Once it is as empty as it will get I open the hot outlet side valve and the highest hot fixture in the house. so that the water from the pipes will drain back into the tank and splash around to try to dislodge more sediment.
I then open the cold in side valve and let that splash around until the drain water is clear.
Close the drain valve, and let the tank fill till the air is out of the house plumbing, once last crack of the over temp valve to flush it out and all is good till next year.
