- Aug 6, 2015
- 3,892
Make sure you look at everything they have so you can spend more than the 3.00 for the labelLMS has the label. So I can get another one. Costs a whopping $3 or so.
It does irk me to spend a very high percentage of the total order on shipping. Spending $8 for shipping on a $3 label, just ISN'T right. At the very least I need to fill the flat rate box, right? Don't worry, I'll find something. I'm on their email list.Make sure you look at everything they have so you can spend more than the 3.00 for the label
I take my comment back. There's room in the front. Your picture proves it. It seems one has to remove the boards for either install. Once that is done there's room in the front face. I like the front mount better.there is room to shoehorn a display in front.. this is the macpod tach kit, simple no fuss, plugs into the LMS wiring.. https://macpod.net/misc/sx2_tachometer/sx2_tachometer_kit_v2.php
I sure Agree their shipping is super high for what they are shipping. I've held off ordering parts from them because of the high shipping. I don't think there is an option with them to use a fixed box size and than who knows if they would even use it.It does irk me to spend a very high percentage of the total order on shipping. Spending $8 for shipping on a $3 label, just ISN'T right. At the very least I need to fill the flat rate box, right? Don't worry, I'll find something. I'm on their email list.
I don't think they are really bad. They do give some options on shipping, including flat rate boxes. I think shipping has gone up quite a bit in general. Buying one little item from them doesn't make sense if you aren't local. But, it's rarely a problem, I usually find enough interesting things to make it worthwhile.I sure Agree their shipping is super high for what they are shipping. I've held off ordering parts from them because of the high shipping. I don't think there is an option with them to use a fixed box size and than who knows if they would even use it.
One thing to be aware of is it has to fit in the flat rate box. The boxes are rarely the right shape. LMS does pack pretty well, so it takes up some space. Can tell you, they are NOT the worst of the bunch.Doesn't seem to work for me if I add more things price seems to just increase with the extra added items. I'm not sure if it is shipping or handling charges will have to check that out.
