- Dec 18, 2019
- 6,464
A year ago I ground a trepanning tool and a crude grooving tool to make my led spindle light. Had a devil of a time with the groover. Didn't have the correct tools for the job really. But the HSS tools I made did work and the spindle light was finished. Don't have a small bench grinder or a decent rest for the grinder. It's the rest for the grinder that makes things easier. The sheet metal rests on common consumer grinders are a joke, they vibrate like mad, aren't even level, and are difficult to set.Threading with the tool upside down, on the inside of the back is less stressful, the tool comes out of the work as it cuts, rather than having to stop before it crashes. With the spindle turning toward you, (conventional) you cut the same direction as when threading outside.
Small bore. Start with a 3/8" HSS tool blank and remove (slowly) all the stuff that isn't a cutting tool. You'll have to be exceedingly careful to leave the threading tool on the end, but it's worth it. You won't be leaving more than 1/2" of thread, so get a narrow grinding wheel, or spend a lot of time with a 3/4" wheel.
I have made a threading tool from a No 0 center drill, captured in a piece of drill rod for ID work, too.
It's all good experience.
But making a tool and using it is satisfying. I'll poke around and see if I can cobble something together.
