- Dec 25, 2011
- 10,525
Jack,
Look at the chart on the front of your QC box. Just left of center is a column headed "SLIDE GEAR". From top to bottom, it reads IN, OUT, OUT, OUT, OUT. This is the column that tells you where the sliding gear should be. The IN position is only used when you need to cut threads between 4 and 7.5 TPI. So 99% of the time, the gear should be OUT. There is a drawing of the chart in the earliest 12" GB manual but not the latest and not in the 10" box manual. I'm not sure about the middle 12" one as although I have a hard copy, I can't lay my hands on it right now and we don't have a scan of it.
The Yahoo Atlas_Craftsman Group Files section has manuals on the ATLAS 1500 and 1570 10" boxes and the first and third version Craftsman 12" boxes. This site (H-M) had the same files in Downloads but I haven't yet had time to check whether they survived the crash and the several month hiatus. We are slowly getting it back up and running with new software (previous provider went out of business).
Robert D.
Robert D.
