- Aug 26, 2013
- 1,061
What's everybody using to get a good surface finish on steel?
I've been playing around with a 1-1/2" 45 degree face mill, that uses SEHT inserts, and while I can get an ok surface finish it's nothing to brag about. If i switch over to the aluminum inserts I get a fabulous finish on every grade of aluminum I've tried.
This is the finish I got in hot rolled 4140, the close up looks worse than it actually is. Sometimes the middle of the cut has a glass smooth finish to the touch. The roughness is always at begging & end of the cut, when only one insert is engaging the work at a time.. I think the issue is that wiper style insert is just to much for my machine in steel.
this is the face mill & inserts.
