In need of a (hopefully) simple turned part
Wolf_LikeMe
Nov 12, 2022
3
Hello,
I've been struggling to find anywhere local with a lathe to turn this part and I was wondering if anyone here would be able to help me out?
I'm in the UK if that makes a difference.
The grade of material shouldn't be to critical and I have designed it from a standard stock size to hopefully make things easier to source and flip in the chuck.
I'm not sure about the feasibility threading the end up to the next face but an undercut can always be added to allow the tool some clearance (so long as it doesn't dramatically weaken the part)
Thanks again!
Hi Wolf_LikeMe,
Just one piece needed?
What's the timeframe?
What are the tolerances for groove diameters and positions?
I'm in NY and can probably get it done in a week or two.
John
Hi John,
Yeah I only really need one piece to see how well it works etc.
It's been on the backburner for ages so there is no real concern about time.
Tolerance wise, it doesn't really have to be anything too critical is something like 0.2 mm feasible for the position? For the diameter I'd be prone to undersize it rather than over size the diameter.
Hi John,
PM me and I will give you a quote.
Glad to help out.
Also, what is the constraint? The 50 deg angle or the 2.25mm length of the angle. I didn't do the geometry to verify.
John
