- Sep 22, 2010
- 7,223
Clockmakers use lacquer sticks to fill in the letters on old clock dials to make them more readable.
The same principle can be used on dials and other surfaces with lettering to improve contrast:
Lacquer-Stik, a solid paint stick made for filling engravings can be used. It is available from many sources at prices from about $1.70 to $3.50 a stick. To use it you have to cut off a thin slice from the end where the paint has dried, or simply rub it on with the stick, then rub in into the lettering using your finger. Just wipe off the excess with a paper towel afterwards. It takes a day or two for the paint to completely cure, but you just have to be a little careful with it and you can use it right away. The paint sticks come in a variety of colors and can be used to renew the engraving on machinery dials also.
You can buy lacquer sticks at clock repair suppliers like www.TimeSavers.com or http://www.micro-tools.com/store/SearchByCategory.aspx?CategoryCode=PAI or at Amazon: http://www.amazon.com/gp/product/B00...tag=acleint-20
Nelson
Nelson
